GRAVEYARD REAPER ANIMATED HALLOWEEN PROP
SPOOKMART
Post by SPOOKMART » Mon May 18, 2015 9:10 am
http://www.spookmart.com/products/grave ... oween-prop
Preorder, available this summer.
"This decor set has it all! The Graveyard Reaper decor set comes complete with a 5'9"" Reaper character featuring a soft PVC head with a moving mouth and light-up eyes, a tattered costume with gauze details and blow-molded hands, a fabric-covered wire-frame 36""-tall coffin that lights up showing a stuffed-fabric rotting corpse with plastic head & hands hanging on the inside, a fabric-covered wire frame 19'-tall tombstone, and a piece of green gauze ""gound cover"" to help set the scene. Plug in the UL power adapter into any standard outlet & choose from Steady-On, Infra-Red Sensor or Step-Here Pad (included) activation options to operate. Once activated, the Graveyard Reaper will open the coffin door as his mouth moves while saying one of three evil coversations with the doomed corpse (e yards THIS close to Halloween. I pull more doomed souls into my bony grasp during this season than any other and it isnt long before you end up looking like this retched corpse. {Aaargh, Death for an eternity. Release me from this torture!} He takes death so seriously. It isnt all that bad. You get used to it after a few hundred years. Ha ha ha.02/16/15 02:53pm SCTH ,e Reaper? Perhaps you should if you dont want to have a pine box fitted for you {Aaaargh. Hes caught me in his cold, cold clutches. There is no escape! Uhhhhhhh I think you would look pretty good in a coffin. Ill be by later to talk you into one. Ha ha ha., d, once they are buried properly. But if they are dug up, their souls are ripe for the taking! I have been lucky this season, so many souls to take. Perhaps you are next! Ha ha ha!02/16/15 02:53pm SCTH ). The infra-red sensor works up to 6.5 bright light to no light! Item includes volume control. Easy-to-assemble quick-connect poles. Assembly required."
Halloween Costumes, Masks, Props and More http://www.spookmart.com
Re: GRAVEYARD REAPER ANIMATED HALLOWEEN PROP
Post by Murfreesboro » Tue May 19, 2015 7:34 am
Wow, that's some prop!
